@devshack
Ich habe nur die 2 Nodes geändert,
und das initialisieren am Timestamp eingeschaltet
"id": "3aaa1940c497732c",
"type": "file",
"z": "d1c583b1ec3b0e75",
"name": "",
"filename": "pekaway/heater_frost_soll",
"filenameType": "str",
"appendNewline": false,
"createDir": true,
"overwriteFile": "true",
"encoding": "none",
"x": 1300,
"y": 320,
"wires": [
"id": "be783c2b59709d66",
"type": "file in",
"name": "frostSollInput",
"format": "utf8",
"chunk": false,
"sendError": false,
"encoding": "none",
"allProps": false,
"x": 520,
"y": 320,
"wires": [
"b22a3a762e8c5a20",
"f46946888115acb1"
"id": "7bce5644a0d919f8",
"type": "comment",
"name": "Frostmodus Temperatur & Laufzeit Sollwert",
"info": "",
"x": 410,
"y": 280,
"wires": []
"id": "625225848342e363",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": "1",
"topic": "",
"payload": "",
"payloadType": "date",
"x": 360,
"y": 320,
"wires": [
"be783c2b59709d66"
"id": "b22a3a762e8c5a20",
"type": "function",
"name": "set type",
"func": "var str = Number(msg.payload);\nglobal.set(\"frostSoll\", str);\nmsg.payload = str;\nreturn msg;\n\n\n\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 680,
"y": 320,
"wires": [
"bf7841e24a9737a9",
"768ce90d96e276bc"
"id": "bf7841e24a9737a9",
"type": "ui_slider",
"label": "Temperatur Sollwert:",
"tooltip": "Als Temperatursensor gilt Ruuvi und/oder Planar Sensor",
"group": "6c33cacc9635fd6e",
"order": 5,
"width": 6,
"height": 1,
"passthru": true,
"outs": "end",
"topic": "",
"topicType": "str",
"min": "-10",
"max": "35",
"step": 1,
"className": "",
"x": 860,
"y": 320,
"wires": [
"fd790d092c1085fa",
"568634d81a52723f",
"cc3d2c874efb6777"
"id": "5c3da94a8db50912",
"name": "frostTempInput",
"label": "Gewünschte Temperatur:",
"tooltip": "Bitte wählen Sie die gewünschte Temperatur aus.",
"group": "eb9d04448cbaca04",
"order": 6,
"width": 6,
"height": 1,
"passthru": true,
"outs": "end",
"topic": "topic",
"topicType": "msg",
"min": "5",
"max": "35",
"step": 1,
"className": "",
"x": 890,
"y": 360,
"wires": [
"47c8f7551398a229"
"id": "7fca4d2ca709a131",
"type": "file",
"name": "",
"filename": "pekaway/heater_frost_temp",
"createDir": true,
"encoding": "none",
"x": 1290,
"y": 360,
"wires": [
"id": "47c8f7551398a229",
"type": "function",
"name": "set value",
"func": "if (msg.payload == \"\")\n{\n msg.payload = \"frostTempInput\"\n}\nglobal.set(\"frostTemp\", msg.payload);\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1070,
"y": 360,
"wires": [
"7fca4d2ca709a131"
"id": "f0c2974e46d2145e",
"type": "file in",
"format": "utf8",
"chunk": false,
"sendError": false,
"encoding": "none",
"allProps": false,
"x": 530,
"y": 360,
"wires": [
"e6b5b786bd205b7e"
"id": "fd08c179f2745fbe",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": "1",
"topic": "",
"payload": "",
"x": 360,
"y": 360,
"wires": [
"f0c2974e46d2145e"
"id": "e6b5b786bd205b7e",
"type": "function",
"name": "set type",
"func": "global.set(\"frostTemp\", msg.payload)",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 710,
"y": 360,
"wires": [
"5c3da94a8db50912"
"id": "fd790d092c1085fa",
"type": "debug",
"name": "debug 229",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "true",
"targetType": "full",
"statusVal": "payload",
"statusType": "auto",
"x": 1050,
"y": 260,
"wires": []
"id": "cc3d2c874efb6777",
"type": "function",
"func": "if (msg.payload == \"\")\n{\n msg.payload = \"frostSollInput\"\n}\nglobal.set(\"frostSoll\", msg.payload);\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1080,
"y": 180,
"wires": [
"713700692b448440"
"id": "568634d81a52723f",
"type": "function",
"func": "\nglobal.set(\"frostSoll\", msg.payload);\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1040,
"y": 320,
"wires": [
"64faafc0630550d1",
"3aaa1940c497732c"
"id": "64faafc0630550d1",
"type": "debug",
"name": "debug 231",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "true",
"x": 1250,
"y": 260,
"wires": []
"id": "f46946888115acb1",
"type": "debug",
"name": "debug 232",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "true",
"x": 690,
"y": 260,
"wires": []
"id": "768ce90d96e276bc",
"type": "debug",
"name": "debug 233",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "true",
"x": 870,
"y": 260,
"wires": []
"id": "713700692b448440",
"type": "debug",
"name": "debug 234",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "true",
"x": 1250,
"y": 180,
"wires": []
"id": "6c33cacc9635fd6e",
"type": "ui_group",
"name": "Frostschutz",
"tab": "9f489dc766d06865",
"order": 6,
"disp": true,
"width": "6",
"collapse": true,
"className": ""
"id": "eb9d04448cbaca04",
"type": "ui_group",
"name": "Test",
"tab": "3a3784166e4077aa",
"order": 1,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "9f489dc766d06865",
"type": "ui_tab",
"name": "Heizung",
"icon": "mi-whatshot",
"order": 8,
"disabled": false,
"hidden": false
"id": "3a3784166e4077aa",
"type": "ui_tab",
"name": "Test",
"icon": "dashboard",
"order": 14,
"disabled": false,
"hidden": false
