Hi all,
A short while ago I had email contact with Christopher and he asked me to post my question here, so here goes:
My vehicle is an 11-2014 MAN TGE, see here for info: Ombouw MAN TGE: - camperforum.nl , in short it is an LWB with a 250A alternator and a 24V household battery with a capacity of 4420Wh. I charge from 800Wp solar using the Pekaway S40 MPPT and just bought 2x Victron XS1400 to charge from the alternator, these can provide 50A each and will be limited to 40A each to not put a higher load on the alternator than 250A * 30% = 83,33A.
It is my goal to build an off-grid vehicle that has a high power electrical system to enable me working remotely having the same comfort as at home, I will probably not even add shorepower as it should never be needed and I also do not visit places with EHU (Electrical Hook Up).
I want to use 2* Victron XS1400 (already in stock) to charge the household battery based on conditions. These conditions need to be programmed in the Pekaway Core Pro using inputs from peripheral devices such as the Pekaway Shunt and Can-bus data and data from internet (weather info for instance) to decide whether to charge the household battery or not. I installed the MPPT in May and have only used solar power up to now, but in all fairness, I switched the fridge off in the second week October. I am adding an Autoterm Air 2D heater very soon and the Baltica heater next year, when the 24V version is market ready.
Back to the technical stuff: I do not want to run a D+ from the terminals under the drivers seat as I need a more intelligent logic than only “engine_running=YES” AND “alternator_provides_15V=YES”.
Goal: I want the Core Pro to start the DCDC’s when conditions are met which will draw a huge load from the starter battery telling the vehicle BMS that the alternator needs to step up and get to work on 15,6V unti the DCDC’s are told by the (data from the Pekaway Shunt inserted into the) Core Pro to stop drawing a load, causing the alternator to (unless other consumers within the vehicle are drawing loads) power off.
The 2* XS1400 will have a BlueSea 4-way switch to switch “Both DCDC-ON, DCDC-1 ON only, DCDC-2 ON only, Both DCDC OFF” and will have the correct cable sizing and fuses. In the back of the vehicle all is Victron, that what is not Pekaway, such as the Lynx M10. Fuseboards are Pekaway.
Initially I will hardwire one small rocker switch into the remote port of each DCDC to manually switch them on/off but once I have the Core Pro on board I want to go automated.
Questions:
- How do I pick up the Can data from the vehicle into the Core Pro?
- Which data types can I pick up from the Can-bus?
- How to integrate CAN-data in the Core Pro?
The Core Pro is not in my posession yet, have to save up…
I will contact my dealer (Roordink in Veenendaal, The Netherlands) to receive as much info as possible about the location of the Can connector too.
My vehicle has the programmable device with extra electrical connector points as seen below.
