bei mir schmeißt der Flow “Pekaway Shunt + WaterLevel Python” auf einmal folgende Fehlermeldung:
{“topic”:“”,“_msgid”:“3dd063a62b16f968”,“statusCode”:200,“headers”:{“date”:“Wed, 19 Apr 2023 12:30:49 GMT”,“server”:“WSGIServer/0.2 CPython/3.7.3”,“content-length”:“1”,“content-type”:“text/html; charset=UTF-8”,“x-node-red-request-node”:“735d287f”},“responseUrl”:“http://localhost:8080/check",“redirectList”:[],“retry”:0,“rc”:{“code”:null,“message”:"Command failed: python3 -u pekaway/ads_py/web1.py\nBottle v0.12.19 server starting up (using WSGIRefServer())…\nListening on http://localhost:8080/\nHit Ctrl-C to quit.\n\nException in thread Thread-2:\nTraceback (most recent call last):\n File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner\n self.run()\n File "/usr/lib/python3.7/threading.py", line 865, in run\n self._target(*self._args, **self._kwargs)\n File "pekaway/ads_py/web1.py", line 215, in thread2\n level1 = adc2.read_adc(0, gain=1)\n File "/home/pi/pekaway/ads_py/Adafruit_ADS1x15/ADS1x15.py", line 193, in read_adc\n return self._read(channel + 0x04, gain, data_rate, ADS1x15_CONFIG_MODE_SINGLE)\n File "/home/pi/pekaway/ads_py/Adafruit_ADS1x15/ADS1x15.py", line 129, in _read\n self._device.writeList(ADS1x15_POINTER_CONFIG, [(config >> 8) & 0xFF, config & 0xFF])\n File "/usr/local/lib/python3.7/dist-packages/Adafruit_GPIO/I2C.py", line 127, in writeList\n self._bus.write_i2c_block_data(self._address, r…”,“signal”:“SIGKILL”},“payload”:“Exists\nDataBase THREAD running, write successful\nerrorUpdateShunt\nerrorUpdateShunt\nerrorUpdateShunt\nerrorUpdateShunt\nerrorUpdateShunt\nerrorUpdateShunt\n”}
Woran kann das liegen?
Kann es sein das deswegen auch die Tanksensoren nicht angezeigt werden?
Vielen Dank schon mal.
