Hallo Vincent,
danke für deine schnelle Rückmeldung.
Hier das Ergebnis aus der Console:
18:33:48.012 MQT: Connected
18:33:48.017 MQT: pkw/tele/PekawayMOTA/LWT = Online (retained)
18:33:48.019 MQT: pkw/cmnd/PekawayMOTA/POWER =
18:33:48.024 MQT: pkw/tele/PekawayMOTA/INFO1 = {“Info1”:{“Module”:“ESP32-DevKit”,“Version”:“12.5.0.4(tasmota32)”,“FallbackTopic”:“cmnd/DVES_49A274_fb/”,“GroupTopic”:“pkw/cmnd/tasmotas/”}}
18:33:48.039 MQT: pkw/tele/PekawayMOTA/INFO2 = {“Info2”:{“WebServerMode”:“Admin”,“Hostname”:“PekawayMOTA-0628”,“IPAddress”:“192.168.9.101”,“IP6Global”:“2a01:599:941:11fb:f665:bff:fe49:a274”,“IP6Local”:“fe80::f665:bff:fe49:a274”}}
18:33:48.064 MQT: pkw/tele/PekawayMOTA/INFO3 = {“Info3”:{“RestartReason”:“Vbat power on reset”,“BootCount”:12}}
18:33:51.928 MQT: pkw/tele/PekawayMOTA/STATE = {“Time”:“2025-03-20T18:33:51”,“Uptime”:“0T00:00:11”,“UptimeSec”:11,“Heap”:124,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:34,“MqttCount”:1,“Berry”:{“HeapUsed”:3,“Objects”:39},“Wifi”:{“AP”:1,“SSId”:“MANV_2G”,“BSSId”:“20:97:27:1E:5A:68”,“Channel”:8,“Mode”:“11n”,“RSSI”:74,“Signal”:-63,“LinkCount”:1,“Downtime”:“0T00:00:06”}}
18:33:51.992 MQT: pkw/tele/PekawayMOTA/SENSOR = {“Time”:“2025-03-20T18:33:51”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.4},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.8},“TempUnit”:“C”}
18:34:01.643 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:34:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.4},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.8},“TempUnit”:“C”}}
18:34:51.595 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:52.646 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:52.694 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:53.245 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:53.296 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:54.047 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:55.097 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:55.697 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:56.750 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:56.800 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:57.149 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:57.349 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:57.949 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:34:58.153 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:35:01.683 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:35:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.4},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.8},“TempUnit”:“C”}}
18:36:01.665 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:36:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.5},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.8},“TempUnit”:“C”}}
18:37:01.676 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:37:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.5},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.7},“TempUnit”:“C”}}
18:38:01.672 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:38:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.5},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.7},“TempUnit”:“C”}}
18:38:47.119 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:38:51.941 MQT: pkw/tele/PekawayMOTA/STATE = {“Time”:“2025-03-20T18:38:51”,“Uptime”:“0T00:05:11”,“UptimeSec”:311,“Heap”:116,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“Berry”:{“HeapUsed”:3,“Objects”:39},“Wifi”:{“AP”:1,“SSId”:“MANV_2G”,“BSSId”:“20:97:27:1E:5A:68”,“Channel”:8,“Mode”:“11n”,“RSSI”:80,“Signal”:-60,“LinkCount”:1,“Downtime”:“0T00:00:06”}}
18:38:52.009 MQT: pkw/tele/PekawayMOTA/SENSOR = {“Time”:“2025-03-20T18:38:51”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.5},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.6},“TempUnit”:“C”}
18:38:54.119 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:39:01.711 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:39:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.5},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.6},“TempUnit”:“C”}}
18:39:03.504 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:39:03.705 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:39:05.158 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:39:05.560 MQT: pkw/stat/PekawayMOTA/RESULT = {“Command”:“Error”}
18:40:01.717 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:40:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.5},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.6},“TempUnit”:“C”}}
18:41:01.587 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:41:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.5},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.6},“TempUnit”:“C”}}
18:42:01.702 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:42:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.5},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.6},“TempUnit”:“C”}}
18:43:01.728 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:43:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.5},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.5},“TempUnit”:“C”}}
18:43:39.923 APP: Serial logging disabled
18:43:51.956 MQT: pkw/tele/PekawayMOTA/STATE = {“Time”:“2025-03-20T18:43:51”,“Uptime”:“0T00:10:11”,“UptimeSec”:611,“Heap”:117,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“Berry”:{“HeapUsed”:3,“Objects”:39},“Wifi”:{“AP”:1,“SSId”:“MANV_2G”,“BSSId”:“20:97:27:1E:5A:68”,“Channel”:8,“Mode”:“11n”,“RSSI”:80,“Signal”:-60,“LinkCount”:1,“Downtime”:“0T00:00:06”}}
18:43:51.993 MQT: pkw/tele/PekawayMOTA/SENSOR = {“Time”:“2025-03-20T18:43:51”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.5},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.5},“TempUnit”:“C”}
18:44:01.746 MQT: pkw/stat/PekawayMOTA/STATUS10 = {“StatusSNS”:{“Time”:“2025-03-20T18:44:01”,“DS18B20-1”:{“Id”:“0822547C32E9”,“Temperature”:14.6},“DS18B20-2”:{“Id”:“07226167B3E3”,“Temperature”:19.5},“TempUnit”:“C”}}
Andreas
