Truma Combi iNet
Hast du einen Raspi PI 5 ?
Was sagt denn dmesg | grep “tty” ?
Raspberry Pi 4
  • Serial Ports : The Raspberry Pi 4 has the following serial ports:
    • /dev/ttyS0 : This is the primary serial port, which is typically linked to GPIO pins 14 and 15.
    • /dev/ttyAMA0 : This is another serial port, which can be used for Bluetooth communication or as a secondary serial port if Bluetooth is disabled.
    • /dev/serial0 : This is a symbolic link to the primary serial port (usually /dev/ttyAMA0).
    • /dev/serial1 : This is a symbolic link to the secondary serial port (usually /dev/ttyS0).
  • Configuration :
    • To use the primary serial port on GPIO pins 14 and 15, you can enable it by setting enable_uart=1 in the config.txt file.
    • If you disable Bluetooth by adding dtoverlay=disable-bt to config.txt , /dev/serial0 will be linked to /dev/ttyAMA0, and /dev/serial1 will be linked to /dev/ttyS0.
Raspberry Pi 5
  • Serial Ports : The Raspberry Pi 5 introduces some changes in its serial port configuration:
    • /dev/ttyAMA0 : This is the primary serial port, which is typically linked to the new UART connector.
    • /dev/ttyAMA10 : This is a new serial port that is linked to GPIO pins 14 and 15.
    • /dev/serial1 : This is a symbolic link to the secondary serial port (usually /dev/ttyAMA10).
  • Configuration :
    • To use the primary serial port on the new UART connector, you can specify console=ttyAMA0,115200 in the cmdline.txt file and set dtparam=uart0=on in the config.txt file.
    • To use the secondary serial port on GPIO pins 14 and 15, you can specify console=ttyAMA10,115200 in the cmdline.txt file and ensure that the necessary configurations are set in config.txt .
Differences and Considerations
  • Primary Serial Port : On the Raspberry Pi 4, /dev/ttyAMA0 is typically used for Bluetooth or as a secondary serial port. On the Raspberry Pi 5, /dev/ttyAMA0 is the primary serial port linked to the new UART connector.
  • Secondary Serial Port : On the Raspberry Pi 4, /dev/ttyS0 is the primary serial port linked to GPIO pins 14 and 15. On the Raspberry Pi 5, /dev/ttyAMA10 is the secondary serial port linked to GPIO pins 14 and 15.
  • Symbolic Links : The symbolic links /dev/serial0 and /dev/serial1 have different behaviors on the Raspberry Pi 5 compared to the Raspberry Pi 4. On the Raspberry Pi 5, /dev/serial0 is linked to /dev/ttyAMA0, and /dev/serial1 is linked to /dev/ttyAMA10.
Conclusion
When working with serial ports on the Raspberry Pi 5, you need to be aware of the new UART connector and the changes in the symbolic links. If you are migrating from the Raspberry Pi 4, you may need to adjust your configurations to ensure compatibility. For detailed and up-to-date information, refer to the official Raspberry Pi documentation.
Hab einen 5er
Werde am Wochenende anfangen mir der Elektrik Neuzulegen ! Dann baue ich mal alles ein und Probier ich es!
Hallo Ihr alle :wink:
ich bin auch dabei meine Tuma anzuschließen, ich hatte zuerst die ESP32 version von Magnus Christ laufen, damit konnte ich die Heizung auch schon steuern, aber die Verbindung riss immerwieder ab, und ich musste den ESP über die Configseite immer wieder neu verbinden.
Also wollte ich jetzt die Version von Daniel Fett wie hier beschrieben installieren.
Das programm habe ich auch schon drauf, aber ich komme nicht weiter. Da ich der totale Raspberry und Linux Legasteniker bin benötige ich Hilfe!!!
ich bin an diesen JST Stecker von meinem blauen Relayboard gegangen
Ich vermute mal das dass der MultiUART im Programm ist also der ttyAMA5
wenn ich nach tty suche wird der auch angezeigt.
bei fuser zeigt er mir das an
grafikd
Das sind die Befehle diee ich hier gelesen habe, aber mir sagen die nix
Bei Truma-Service bekomme ich das angezeigt.
in meiner miqro.yml steht das drin
was kann ich tun um weiter zu kommen.
@Vincent
Hallo Vincent
Der jst Stecker oben im Bild. Ist das der AMA5 Multi Port UART 5???
Hallo Arno, ich hatte den AMA5 in Node-Red Flow “Connections” disable selected nodes/appearance gesetzt.
Serielle Ports:
https://pinout.xyz/pinout/uart
Verwendet für Truma: J12 = UART5 PIN 33 (GPIO13)+PIN 32 (GPIO12) → prüfen ob der dorthin geht.
In der config.txt konfigurieren:
/dev/config.txt
[all]
#dtoverlay=vc4-fkms-v3d
dtoverlay=w1-gpio
enable_uart=1
#dtoverlay=uart2
#dtoverlay=uart3
#dtoverlay=uart4
dtoverlay=uart5
Gruß, Stefan
check mal den seriellen Port mit einem Terminal Programm:
minicom Terminal:
sudo apt-get install minicom
Port zuweisen für Test:
sudo minicom -b 9600 /dev/ttyUSB0Abfrage:
# UART0 (PL011): /dev/serial0 → /dev/ttyAMA0
# Linux kernel serial console
# GPIO 14: TXD0
# GPIO 15: RXD0
# UART1 (miniUART): /dev/serial1 → /dev/ttyS0
# disabled
#enable_uart=1
# UART2 (PL011): /dev/ttyAMA1
# GPS UART
# GPIO 00: TXD2
# GPIO 01: RXD2
dtoverlay=uart2
# UART5 (PL011): /dev/ttyAMA2
# Tester UART
# GPIO 12: TXD5
# GPIO 13: RXD5
dtoverlay=uart5
After merging Bookworm changes from current arm64 branch the device enumeration changes and there are UART warnings in the kernel log:
UART GPIO pins kernel device connected to
UART0 14/15 ttyAMA1 tester console
UART2 00/01 ttyAMA2 GPS
UART5 12/13 ttyAMA0 Linux console
To make sure that the issue is not caused by our customization, I installed official Raspi OS Lite/Bookworm image on a Pi 4 Model B. After adding the lines to /boot/firmware/config.txt & rebooting, I was able to reproduce the issue.
Gemessen Ports auf RPI 4:
NEXION RJ45 RX 9 (/8 TX Display/GPS
UART1 J16 RX 8 (GPIO14)/10 (GPIO15) TX
UART4 J11 RX 21 (GPIO9)/22 TX
UART5 J12 RX 28 (GPIO1)/30 TX (GPIO LIN BUS Truma
Hier steht auch noch etwas zu den seriellen RPI Ports und Terminal Prg:
Probiere ich demnächst mal aus, bin zur Zeit wieder mit dem ESP32 zugange, läuft jetzt seit 2Tagen ohne sich abzumelden, wenn das weiter funktioniert ist mir das auch lieber, als direkt auf die Himbeere. Ist weniger Arbeit beim Update :wink:
Die Platine die ich gebaut habe kann beides
